First post, by keropi
- l33t++
Hiya!
because my newly-acquired XT machine only has 2 free ISA slots I am thinking of expanding the busboard with a couple more... Here is a pic of the busboard, bottom two slots are occupied by the CPU and CGA-I/O cards:
as you can see at the top there is place to solder another slot - or some extension to connect 2-3 more of them 🤣
There is plenty of empty space behind the drives, good enough to fit some smaller cards that don't need to be accessed like XTIDE or an EMS ramcard to name a few.
So , would some nicely soldered short wires (or short wires with a pin connector to connect original and addon boards) along with some decoupling caps work OK?
I don't see a reason why this shouldn't work since the addon cards I plan to add are low-powered ones but maybe someone here has more experience with this? Ideally I'd like to add 3 more 8bit slots. I know jwt27 did something similar here: Short on ISA slots? Try this. but this was a pre-made ISA busboard with some external PSU as far as I can tell.
TIA for any info/help! 😊
