First post, by Half-Saint
- Oldbie
Hi guys,
haven't posted in a while, been busy with other things.. anyway, I noticed that there are quite a few P5A-B users on the forums and maybe you guys could help me out. I'm using HWMonitor to read temperatures and that's what's puzzling me. The program gives three temperature readings: TMPIN0, TMPIN1 and TMPIN2. What's what?? Off the top of my head, the first reading is around 30C, the second around 38C and the third around 48C. I'm guessing that TMPIN2 reading comes from the CPU but it might be bogus. I took the heatsink off immediately after shutting down the PC, made a measurement with an IR thermometer and it only showed 28C! To make things more puzzling, none of the two big chips on the motherboard read more than 37C with the thermometer.
I used to run this PC with a passive cooler - Zalman CNPS6000-Cu but not really sure that's smart yet I really dislike the fan noise.
Hoping for some input 😀
PROBLEM #2
I got the latest version of Opera that'll still run on Windows 98. The problem is, it's crashing most the time! I'll just close itself and offer to send a report. Sometimes I can't even start it up anymore and have to do a system reset. The other problem is that at random times Windows report that some application or another has crashed. I just have to restart that app and it'll work. But I'd rather avoid this altogether! Already tried memtest and both sticks appear to be fine.
Ideas?
Cheers,
Saint
UPDATE: just left it running with HWMonitor in the background and it crashed again. This time EXPLORER.EXE crashed, taking everything else with it. Had to do an actual reset to get it back up. I tried different ram and it's still acting up.
