First post, by carlostex
- l33t
I just got a lot of ISA sound cards on eBay. Among the most interesting were the Aztech Sound Galxy Waverider+ and the Guillemot Maxi Sound 64 Lite.
The Guillemot sports an ESS Audiodrive ES1868F chipset and a SAM Dream 9407 wavetable chipset. It includes 1MB ROM and the card also sports 2MB RAM to load soundfonts.
The soundfont that comes by default on the drivers is pretty good, i was really impressed how good it sounded in games like Duke 3D, Tyrian or Warcraft 2. Very nice.
The ESS chipset is well known though. I personally don't have a lot of experience with them, but i was satisfied with its register compatible OPL3 FM synthesis which sounds very close to the real thing. Only the FM freaks (like me) will care or notice subtle differences. Try hard and you'll notice. But pretty good.
I'm not impressed however by the ESS codec. It seems inferior to the Sigma-Delta codec included on the Yamaha YMF-71x cards. Even games like Wolfenstein 3D showed less playback quality compared with OPL3-SAx cards. On Inertia Player the ESS chipset doesn't seem happy to play in Sound Blaster Pro mixed at 44KHz. Now i know the original SB Pro 2 could only do 22KHz mixing, but try an OPL3-SAx card, it can do 44KHz in SB Pro 2 mode. I guess every card has its own quirks. But i'm left wondering if any of the other ESS chipsets might be more advanced. I checked the datasheet and it claims the ES1868 does support programmable sample rates up to 44KHz though. Digital samples on the ESS card doesn't sound that great, unfortunately, at least when compared with other cheap cards.
I was however very impressed with the SAM chipset, and i don't even have a SIMM installed. This card does have a SIMM slot for RAM expansion, which as far as i know, can go up to 16MB. With good soundfonts, this card can really really shine.
The DOS drivers have a hard time recognizing the card. It seems it tries to check the card presence via PnP resource address, and then initialize it. I was fed up with it, so i just used the ESS DOS config utility to light the card up and then the Guillemot utility can finally see it. Weird, but it works.
I didn't try, but i belive it works OK with SoftMPU too.
All in all, a very nice card!
