First post, by T4600C
I have a problem with my Compaq Presario 7210, an old 90's desktop.
I cleaned the windows 95 folder of some stuff that I wont use anyway. And cleaned some folders in 'program files'
I must have removed some importand files by accident, as I can no longer enter 'setup mode' in the Compaq bios, I get the error message 'error runtime overlay' and then it returns to to the bios' main screen.
Does anyone here have a computer of the 7000 line? then the software/drivers would be appreciate. Are there any unerase/restore programs for MS DOS/windows 95?
Thanks for your help.
Reply 1 of 8, by brostenen
Don't think you need any software in order to enter the BIOS setup.
It's normally F10, F12, F2 or DEL when turning the machine on.
Reply 2 of 8, by ODwilly
Good thing to note with these old Compaq systems is that they store part of the bios in a folder on the hard drive, which is really stupid. If the system came with any backup diskettes or anything like that give those a try.
Reply 3 of 8, by T4600C
I can enter the bios with F10, but I can't get to any settings to change.
I have read that the menu to change settings is called 'setup' but the BIOS crashes when I do that. It uses a special diagnostic partion on the HDD for that, I will try to reinstall it. http://h10025.www1.hp.com/ewfrf/wc/product?cc … =94444&sw_lang=
Reply 4 of 8, by brostenen
A little searching....
http://support.hp.com/us-en/document/bph07110
Reply 5 of 8, by brostenen
Never knew that. Thanks for the info. 😀
Reply 6 of 8, by T4600C
Got it fixed. I installed an update that fixed a known setup bug in the BIOS when windows 95 is installed.
Patch can be found here: http://h10025.www1.hp.com/ewfrf/wc/softwareCa … &sw_lang=&#N879
That link also provides a diagnostic/boot file, so you can run SETUP from a diskette and still change system settings that way.
For some reason, I can't find '7210' anywhere, the 7212 seems to be next to identical however.
Cheers
Reply 7 of 8, by brostenen
Yeah... They pretty much had a zillion versions of the same stuff. Just the way apple did it too, IBM, and a lot of other big players.
I remember it as something like, a brand new model (they allways said something like that) and it was allways like an "old wine on new bottles" approach.
Basically speaking. You just had a basic model number (7000, 8000, 9000 and so on) and all they did was just something like selling the same machine.
Just with a TNT2 card, instead of something like a Voodoo3 card. Or the other way around. Well... I think you get it. 😉
Reply 8 of 8, by calvin
Another reason to do it was to placate retailers: you have a model configuration number that's basically sold in one store, so you can't price match it. Walmart is selling a Power Macintosh 5200CD, but Circuit City is selling a Power Macintosh 5204CD? Too bad.
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P4 2.6, 1 GB DDR1, Radeon 9600 Pro, P4P800, Windows XP
Alpha 21164, 512 MB, Permedia 2, KZPCM, AlphaPC 164, NT 4.0
