First post, by markot
Are there still any new ATX PSUs made that give -5 volts? I have a couple of old ones, but I don't know the history of them and I'm usually a bit scared about electrical stuff when I don't know where and how they have been used.
Reply 1 of 7, by PhilsComputerLab
I believe there are. StarTech sells one for example. What I do is use an ATX to AT adapter with a -5V converter. They aren't really cheap, but I can use modern power supplies without having to worry about reliability.
YouTube, Facebook, Website
Reply 2 of 7, by Kodai
I too use a converter for -5v. Using old PSU's from the -5v era tends to be a crap shoot right now. Most PSU's of that era were generic and after 15+ years should be rebuilt with new caps and other passive parts if they under heavy use for years (and that's hard to determine if its a second hand unit). The converter allows you to use a modern, branded PSU for vintage hardware like Pro Spectrum's or Roland midi cards.
Reply 3 of 7, by GeorgeMan
One can build a converter.
All you need is an LM7905 and a couple of small caps. Cost? About 1-1.5 USD max 😜
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 4 of 7, by Joey_sw
Why more PSU makers deprecates the -5V? is there any specific techninal reasons why they were doing that?
-fffuuu
Reply 5 of 7, by alexanrs
It is not part of the standard anymore, and no PCs without ISA slots can use it.
Reply 6 of 7, by Logistics
Don't you also need to add some wiring to the main harness? I'd like to hear more about this DIY converter.
