First post, by markot
I installed an old Abit AB-BM6 motherboard today. When starting the computer, I will get the following error message:
CPU is unworkable or has been changed. Please recheck - CPU SOFT MENU
I have not managed to solve this problem. If I change BIOS settings to ignore errors, then this is not shown, but what may be the reason? There is some Intel Celeron CPU on the motherboard.
Reply 1 of 4, by jwt27
It means you need to check the CPU settings (bus speed and multiplier) in the BIOS. If these are wrong, the board will run in fail-safe mode (66MHz)
Reply 2 of 4, by markot
I have tried different settings for the CPU in BIOS, but after saving and restarting computer, they are always changed back to the default values. Somewhere I read that the battery replacement would help, but I'm not sure because the other settings are not changed.
How should the battery be removed from this kind of clip?
Reply 3 of 4, by kanecvr
Your CMOS battery is dead. Remove and replace it. Don't pull on the metal clip, it will break. There is a bit of plastic on the side you can push on to remove the battery. It's a standard CR2032 3.3V coin-cell battery, easily found in most shops, even some corner stores.
Reply 4 of 4, by markot
If the battery is dead and the computer is plugged to the AC outlet, shouldn't it keep the settings in that case anyway? But I will replace the battery and test if it works. This battery is old I think.
