DMA Problem
First post, by Vyothric
Hi. I've been having some trouble on my 486...
The problem is that the computer will sometimes freeze when playing sound. I eventually narrowed down the problem to using DMA 1, suggesting there's some kind of conflict but I can't see where/why there would be. Using DMA 3 is fine, but then obviously the games that only use the default (1) don't detect it and I'm left in silence 😵
The same thing happens with two different sound cards (SB16 CT2230 & CT2830).
Any ideas?
Mastodon | YouTube
Reply 1 of 12, by PhilsComputerLab
What other cards do you have in your machine?
YouTube, Facebook, Website
Reply 3 of 12, by PeterLI
Try a different I/O card. Try resetting BIOS to default settings.
Reply 4 of 12, by Anonymous Coward
Is it a pre 1992 486 motherboard? There was a time in the early 90s when many 386 and 486 systems shipped with faulty DMA controllers. If yours is socketted, it may be replacable. Though, I thought it was related more to high DMA.
Reply 5 of 12, by Vyothric
It's a 486-VC-HD. From 1992 apparently.
Mastodon | YouTube
Reply 6 of 12, by swaaye
I had an all ISA late 1992 486 with Symphony chipset and a SBPRO2. Digital audio in X-Wing in particular would freeze it. I had to run the game with FM synthesis effects. There was no workaround that I could find. But I only recall X-Wing being a problem.
Reply 7 of 12, by Jepael
What CPU you have in there? Did you try to slow the board down or add wait states?
Reply 8 of 12, by Vyothric
Tried both.
DX/2-66. Haven't tried wait states, wouldn't know what to change it to.
Mastodon | YouTube
Reply 9 of 12, by NJRoadfan
Random question, are you using any memory managers like EMM386 that put the machine into v86 mode?
I have a similar problem with a 486 motherboard that I traced to a faulty keyboard controller. When any attempt to play sound is made, the PC speaker would start beeping and keyboard input would stop responding. It only happened when the machine was in real mode though. If EMM386 was installed and the machine in v86 mode, the problem would be masked for some reason. Swapping the keyboard controller fixed the problem.
Reply 10 of 12, by Anonymous Coward
While this board does not have a discrete 82C206 DMA controller, it does have a VIA chipset. I have not used VIA's 486 offerings, but I did have DMA problems on their Pentium products.
Reply 11 of 12, by Jepael
Vyothric wrote:
Tried both. […]
Tried both.
Bigger wait states is slower. I think it does not affect DMA though, just IO cycles. The multi IO card does not seem to have ECP parallel port which could take one DMA channel (3 or 1, no idea what would be the default).
Since it's a DX/2-66 the motherboard runs at 33MHz, so usually the ISA bus runs at 8.33 MHz then. That's quite fast but should work. Can you underclock to 25MHz or 20MHz FSB so CPU is 50MHz or 40MHz?
Reply 12 of 12, by Anonymous Coward
Some motherboard BIOSes let you set the DMA clock rate higher than the standard 5MHz. You might want to check to see if you have this option and what the driver it set at.
