First post, by mr_bigmouth_502
- Oldbie
I know full well in advance that Win95 is not supported in DosBox, but I wonder, would it somehow be possible to use some version of DosBox to network with someone over the internet, and play Win95 games that require IPX? The only way I could think of would be to use the NE2000 passthrough in the ykhwong build, and tunnel it with some external software. Specifically, I'm trying to play the original Microprose Magic the Gathering, which has some compatibility and speed issues with newer systems. I figure DosBox would work for it, since it can run faster than PCem, while still allowing you to limit the overall speed.
