First post, by 386SX
Hi,
I have to change some cmos 3.6v battery on a couple of mainboard that had battery acid on the pcb and dust so I'd like to clean it before soldering. I tried to use some eletronic cleaning spray but it seems it dry almost immediately. What can I use? The acid after so many years became of a blue color near contacts and the dust is really sticky.
I would not like to put them under water.. can I use simple home alchool?
Thank
Reply 1 of 8, by Stojke
Its not acid its base. Use vinegar and an brush. Apply vinegar for some time and gently brush.
Base is nasty and can get under the copper trace and break it. As well as get into middle layers of the board.
Reply 2 of 8, by 386SX
I think that some trace is in fact broken where traces are blue...
Vinegar like the usual usual cooking red vinegar right? 😁
Reply 3 of 8, by Stojke
Yeah. When acid and base mix up they get neutral. A few minutes should be enough. Clean with water after.
Reply 4 of 8, by 386SX
Well, cleaning up a 386 motherboard with vinegar I discovered bad traces but also some disk ceramic orange rounded component opened in half, they are labeled as "C6" for example so they should be capacitors but they didn't have any numbers into it. How can I know with what to replace it?
Reply 5 of 8, by 386SX
I've seen that on other positions on the mainboard there're others with 103 onto it (so 0,01uf ?) but the voltage? The capacitor a small like 3/4mm.
Reply 6 of 8, by smeezekitty
The voltage isn't that critical. There is no higher than 12V on the board anywhere so a 16V cap would be enough
Reply 7 of 8, by 386SX
Ok! I will buy both battery and some 0.01uf capacitors to replace but I've doubts this car will boot..
Reply 8 of 8, by keropi
correct , ceramic caps marked 103 are 0.01uF , their usual voltage rating is 50v or 63v - so no need to pay attention to it for a mobo
