First post, by lolo799
After the regular DV-7, here is the upgraded model DV-7DL, still running under BeOS 5 Pro.
Specs:
Motherboard DFI GIC68-D
http://www.motherboards.org/mobot/motherboard … _d/DFI/GIC68-D/
chipset 815E
Celeron 1200MHz
256MB PC100
Intel Integrated Graphics with an AGP 2x/4x port, compatible with a GPA card (Graphics Performance Accelerator card with 4MB display cache.)
AC97 audio
RealTek 8100 LAN
As you can see there, it has a slim dvd-rom drive with an adapter, weird idea not to go with a regular 5.25" drive...
65.42 KiB
48.21 KiB
The RJ45, parallel, joystick, serial and audio connectors are hidden behind the plate.
91.4 KiB
757.26 KiB
420.7 KiB
Some screenshots of the installed software:
Reply 1 of 2, by calvin
Always like to see BeOS on old rigs. Odd that they hid the Ethernet port though, and they're using the Platinum-lookalike theme. That's also weird, not seeing the Real entries and so on in the about screen...
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P3 866, 512 MB RDRAM, Radeon X1650, Dell Dimension XPS B866, Windows 7
M2 @ 250 MHz, 64 MB SDE, SiS5598, Compaq Presario 2286, Windows 98
Reply 2 of 2, by lolo799
It's supposed to be a stand-alone machine, Roland provided upgrade on CD to update the editing software or install the extra fonts.
36.91 KiB
