Windows10 Compatibility
First post, by iggynerd
I have downloaded and installed DOSBox 0.74 (Latest and Greatest) but it does not seem to run on my Windows10 OS PC, it worked fine with Windows 8.1 but as soon as Windows10 was installed it stopped working, I have tried Compatibility Mode and even run as Administrator, no go, Any thoughts? any other recommendations?
Reply 1 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
Most people report it working just fine on windows 10.
I'd check your graphics driver if I were you.
Water flows down the stream
Reply 5 of 13, by Wanderin65
I'm getting a green background on my DOS Box in Windows 10. How do I get it back to black and functioning?
Reply 6 of 13, by xderpx
Doesn't run for me either. Just immediately errors out with this:
Reply 9 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Scali wrote:
DosFreak wrote:
Did you download dosbox 0.74 from http://www.dosbox.com?
I don't see a 64-bit version there.
And there isn't supposed to be one. You don't need a 64 bit version but dosbox.com is the correct place to get Dosbox...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 10 of 13, by Scali
My point is that the error dialog is showing 64-bit pointers, so it's not an official DOSBox release.
Reply 11 of 13, by xderpx
Yes, it gives the same error. It also memory leaks, quickly taking up more n more RAM until the error message pops up.
Reply 12 of 13, by xderpx
Fixed the error, turns out it was because i had one monitor plugged in to onboard, and the other in to my gpu. I unplugged the onboard, reinstalled my nvidia drivers and now its working.
Reply 13 of 13, by dnewhous
So, external MIDI modules still work with a USB adapter cable in Windows 10?
Daniel L Newhouse
