First post, by 100%
100%
Offline
http://www.recycledgoods.com/hp-7980a-9-track β¦ eel-270-mb.html π π https://www.youtube.com/watch?v=CEL8wnW5uvs π
Both drives are connected to a standard PC with two SCSI host adapters, because "IBM" is High Voltage differential (HVD) and "HP" is standard low voltage differential, single ended (LVD SE). Those devices cannot be on same bus - damaged could occur!!! This PC is running Linux, because it has native support for SCSI tape drives.
HI-I search 95-8-xp drivers
fully kitted
