First post, by emosun
- Oldbie
A while back I posted a case I had found in a computer shop asking if anyone had ever seen one like it before. Well now I know it's a foxconn made (or at least patented) in early 2000. The unique feature of this case being the translucent blue plastic shell. It's one of the last surviving ones , being that , I haven't found a single picture of another one on the internet at all.
I decided to finally put a computer in this case which has never been used. I started a build log over at teksyndicate but I thought I would also share with the retro computer fans as well.
I of course will not be altering the blue plastic shell or the beige front pieces. I did update the internals though to support a newer machine
and by update , essentially just gave it a coat of black , two 120mm fans and some bolts to allow the air under it
