First post, by markot
When powering off the computer, the PS/2 mouse and keyboard doesn't turn off. I have not found any place in BIOS for this feature. Motherboard is AB-BM6. Is there anything that could be done except removing the power cable?
Reply 1 of 6, by leonardo
You probably have a feature called 'power up by keyboard' or something similar in there. It enables you to start the computer by pressing a specific key or key combo without having to reach the power button on the case. Turn that off and your keyboard should power down as well...
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 2 of 6, by Sammy
Or maybe there is a jumper for that on the Mainboard.
Reply 3 of 6, by alexanrs
See if the motherboard has a set of two jumpers near the PS/2 jacks. They control if the power to the keyboard and mouse come from the 5V or 5VSB line.
Reply 4 of 6, by dr_st
Some boards have jumpers, but I am not sure this one does. According to the manual, there is a setting in the BIOS --> Integrated Peripherals, called "Power On Function" which allows waking up the system by keyboard/mouse.
Perhaps setting it to "Button Only" will allow the mouse/keyboard to power off, but maybe not.
Reply 5 of 6, by markot
"Button Only" option doesn't seem to affect and there are no jumpers for this. But otherwise this computer seems to work very well.
Reply 6 of 6, by dr_st
Then I guess you are stuck with it. It seems that the board always takes the PS/2 power from +5V standby. But as long as it does not cause any wakeups you don't want, it's a non-issue.
