As the usb system problem fix, I managed to try the same for the wifi card.
I did a swap from the pci slot and I placed it on the pci slot that's doing the isa bridge btw isa and pci...
I'm posting from that computer, and I think I'm running for about 5 minutes withoutfreeze, so I think it's a good sign (my default freeze time was 12 minutes when the wifi is connected so I hope it'll survive for at least some minutes more D:)
EDIT: pff it was too good to be true xD.
The system froze when I was changing btw google web and google images.
90% of the crashes were when I was running Firefox, I'm gonna try only using ie and see if I can freeze it
EDIT2: Nop, freeze on ie6 too ;--;
well, I noticed that on kernelex, when I set to xp mode, the software is diferent, but I can't open it, maybe there's a combo software, if it's running xp it'll open a software x, and if it's 98, maybe it's running another outdated software
EDIT3: WTF
I'm playing like 20 minutes of quake 2 online on the same computer, and still no freeze, could be something in specific that is doing all the problem with browsers? (maybe the tcp itself?) or ipv6
EDIT4: Only because I said >.> ...
The game froze when the second round finished, it froze in the loading screen, I can't do nothing, but keyboard leds can be turned on and off this time
EDIT5:Alt tab worked and when I did it, quake 2 was closed, AND, the wifi was disconnected 😮, I needed to reescan teh wireless signal to find my wifi again
