First post, by Indrid Cold
- Member
As also written in the thread about the new purchases, just today (along with an IBM ThinkPad 370C) I got this laptop from the early 90s, a 386SX equipped with hard-disk and floppy drive. The person who gave it to me reported that (trying it with a universal power supply) only charging led lights up, and that the laptop will not turn ON nor turns ON the video.
I'll post photos of this model, as you will see (after disassembled) I realized that two flat cables are unhooked from their seat: one wider and brown appears to come from the display while the other came off from near the status lights and power switch.
Connecting it to the power supply, the charging led lights up while power led doesn't, but I can clearly hear the sounds of the POST routine, ending with beeps - unfortunately screen does not light up anything.
Have you idea about how I might move to restore it and maybe bring it back to life? I feel clearly that POST loads normally at start, but those unhooked flats might create problems such as lack of video signal. Do you have any advice on how I could try to reattach these very delicate little flats in the right site?
