First post, by Beaver
I have successfully installed VDM Sound system and tried to run Interplay's Blackthorne DOS game under Win 2000/XP. It runs extremely slow, almost impossible to play.
Any idea how to tweak the VDMS to make the game run faster?
Thanks in advance for your reply.
Reply 1 of 4, by eL_PuSHeR
I remember to have tested BlackThorne not so long ago under WinXP and worked properly for me. Have you tried tinkering with advanced speed options under VDMSound?
Reply 2 of 4, by Beaver
I tried everything I could think of, but it simply won't work. If you have a concrete solution, I'll be grateful.
Thanks for your help.
Reply 3 of 4, by eL_PuSHeR
I will test it again when i arrive home. I am at work now...
Reply 4 of 4, by Guest
So am I, thanks again.
