First post, by Malvineous
Hi all,
I found a PCI-Express to 2x PCI device on DealExtreme and I'm wondering whether anyone here might know how it works?
It looks like the PCI-E card it comes with doesn't have any logic on it, but it just breaks out one PCI-E lane and puts it over a USB 3.0 cable. The other board seems to have some kind of PCI-E to PCI bridge chip on it. So I'm assuming you can't plug the PCI board into any old USB 3.0 slot.
I've seen other adapters like this one which just appear to mount a low-profile PCI card in a PCI-E slot, presumably using the same bridge chip.
If either of these are a direct hardware translation to the PCI-E bus (i.e. no drivers) does that mean you could put a PCI SoundBlaster card into a modern PC (one with only PCI-E slots) and be able to use it with SB16-compatible DOS games?
Reply 1 of 5, by alexanrs
Just beware that you can't even use a PCI SoundBlaster in DOS in late PCI chipsets, as they do not support a few features (mostly related to NMI and the DMA controller) needed by the SB16 emulation.
Reply 2 of 5, by swaaye
Rank Moderator
Moderator
My X-Fi PCI hated being on the fake PCI of my Z68 motherboard. Lots of audio distortion and problems. I frequently needed to reboot to make get it working after sleep. That't basically the same as an adapter. Audigy 2 worked alright though.
Sound cards tend to make any sort of bus problems very apparent.
I would research the bridge chip they use.
Reply 5 of 5, by swaaye
Rank Moderator
Moderator
Yes that's what I mean. It doesn't have the same properties as a native PCI bus and some cards do not work correctly. Bridge chips vary in quality too.
