Warcraft 2 setup
First post, by loskutik09
Hello
I have an original Warcraft 2 iso file. I've mounted it via Daemon tools with drive G:
I have to install game into the system. I've started DOSBox and typed:
mount d g:\
It mounts virtual disk G like a D: at DOSBOX.
Then i type d: and start setup.exe. The setup is starting but then it crashing with HEX symbols. 😒
System: Notebook Asus X550L, Windows 10, x64.
Please help.Thank you
p.s. I don't want to play "preinstalled" (=cutted) version from many sources in Internet. I want to play it with an original music etc.
Reply 1 of 4, by ripa
.iso doesn't contain soundtracks. Anyway, did you mount c: drive first? Maybe the setup expects C drive to exist.
Reply 3 of 4, by Dougsharley
I have a question on the same game. I have the original CD-ROM and can get it to play properly in DOS box but every time I close it out, I need to re mount the CD-ROM and then reinstall it. Then any game play I tried to save is gone. Any input on how to fix this issue.
Reply 4 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Folliw the 60 seconds guide, install the game, keep the mountings and start the game from the mounted c drive's directory WC installed to.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
