First post, by PhilsComputerLab
- l33t++
Hello everyone,
I've got a Wing Commander III installation and everything is working fine. However when I access the key mapper DOSBox crashes.
The error message is
Exit to error: Could not initialize video mode for mapper: DirectDraw2::CreateSurface(PRIMARY): Not in exclusive access mode
This can be resolved by using ddraw output.
The computer runs Windows 10 64 bit and Nvidia card with latest drivers. I don't recall having this issue before, so curious if there is a way and it might have something to do with Windows 10.
DOSBox version 0.74 Copyright 2002-2010 DOSBox Team, published under GNU GPL. --- CONFIG:Loading primary settings from config fi […]
DOSBox version 0.74
CONFIG:Loading primary settings from config file ..\dosboxWC3.conf
CONFIG:Loading additional settings from config file ..\dosboxWC3_settings.conf
MIDI:Opened device:win32
Using joystick T.16000M with 4 axes, 16 buttons and 1 hat(s)
CPU speed: fixed 51000 cycles. If you need more than 20000, try core=dynamic in DOSBox's options.
Fast Forward ON
Fast Forward OFF
