First post, by manbearpig
- Newbie
So, I'm not too familiar with the memory map of a Windows PC, so I follow guides to setup my config.sys/autoexec.bat files. The most recent site I found looked pretty good, so I set mine up like this: http://madsenworld.dk/con_auto/index-uk.htm
Anyway, I think the EMS settings are using resources that the virtual file allocation table uses, because I keep getting VFAT blue screens when trying to start windows. I think the problem is this memory range... I=B000-B7FF, but I'm not sure what to change it to? I ended up taking emm386.exe out of my config.sys file, and it currently looks like this:
NUMLOCK=ON
BREAK=ON
DEVICE=C:\WINDOWS\HIMEM.SYS /V
DEVICEHIGH /L:2 =C:\WINDOWS\SETVER.EXE
SHELL=C:\WINDOWS\COMMAND.COM C:\WINDOWS\ /E:1024 /P
All of that works. When I try to inject:
DEVICE=C:\WINDOWS\EMM386.EXE RAM /MIN=0 I=B000-B7FF /V
I get the BSOD when booting Windows. DOS starts fine.
BTW this is on Windows 98 4.10.2222
Premio 212B motherboard (MSI MS-6112)
Intel PentiumII 333MHz Slot 1 66MHz bus
384MB ECC 66MHz
SIIG ATA133 controller --> Seagate Barracuda 80GB
SIIG Gigabit Ethernet (RTL8169) / USB 2.0 / IEEE1394 controller
ESS 1869 soundcard on board wavetable synth
