First post, by kixs
- l33t
Here we go 😁
Ever since I got the PC retro bug I wanted to get a decent 286 board. Search was long and hard but after many years I think I found it. The motherboard itself is unknown to me. I used to have Octek Fox II Rev. 3.2 with Siemens 286-16 back then and it was fast. So I wanted it or something equivalent.
In it's original form it had Siemens 286-16 and 32MHz crystal. It also had AMD 287-10 math coprocessor. I upgraded it to it's current maximum configuration.
- Harris 286-20 overclocked to 24MHz (crystal is 48MHz)
- Intel 80287XL
- 4x 1MB 60ns 30-pin SIMM
With 50MHz crystal it freezes in DOS. I'll try to get a real Harris 25MHz one day 😉
The tests where done with Cirrus Logic 5429 2MB and some generic I/O controller.
On to the screenshots:
and to the benchmarks. Let them tell the story... 😁
3DBench 1.0 & F1GP Adelaide (default settings with PC speaker):
These are all best case results. BIOS doesn't have any settings. The numerous jumpers don't do much. At least I can't see the difference.
Things to come... maybe put everything in a nice case. Try some more benchmarks, even Windows 3.10 ones. It would help if there exist a Windows acceleration graphic card that supports 286 😕 I'll also try AutoCAD 10 with different math coprocessors (AMD, Intel, IIT, Cyrix). Only missing Cyrix 287XL+, but should be on the way (so says someone in China).
Does any other game have processor usage display that runs on a 286? Any other benchmarks I should try?
/me happy 😁
