First post, by technobebok
Hi!
I wonder if there are any cards which would support MPU-401 output through gameport when played dos-windowed games in win98se? I know that Sound Blaster PCI cards have legacy driver installed in win98, but setting-up games to play music with "General MIDI" or "MPU-401" just uses emulated wavetable synthesis and i don't want that.
For example i would want to:
1. setup DOOM (dos-windowed) in win98se
2. choose General MIDI on port 330
3. plug external synthesizer with gamport->midi cable
I'm just searching for a PCI or ISA card which would let me output midi through gameport in windows 98 BUT when playing dos games in dos-window, without all this general midi wavetable emulation crap. Any suggestions?
Reply 1 of 5, by PhilsComputerLab
What most people do to use external MIDI gear through DOSBox is use a USB MIDI adapter.
But what you propose should also work.
Open DOSBox and type
mixer/listmidi and it well show you a list of available MIDI devices.
Reply 2 of 5, by technobebok
I meant native DOS in Windows98 operating system (eg. command prompt). Not the DOSBox emulation software 😵 my fault - should not use "dosboxed" word 😵
Reply 3 of 5, by PhilsComputerLab
Ah ok 😀
So it must be a PCI card?
The Aureal Vortex 2 can do that. It has a driver setting to toggle between external port and wavetable header.
Reply 4 of 5, by technobebok
or an ISA. My MOBO has one free ISA slot 😀
for now i can buy Aureal Vortex but v1 eg. AU8820B2. Do you think it has the same option as you mentioned?
Reply 5 of 5, by PhilsComputerLab
Well if you've got an ISA slot, than you are spoilt for choice 😀
Any SB16, 32 or 64 will do. As will many other cards, like Yamaha based like the Audician 32 Plus.
