AWE64 Gold Setup
First post, by Ticondrius
I'm trying to configure my AWE64 Gold for use in DOS and Win98SE. I've got all the drivers from the vogon driver library, as well as an original AWE64 CD. Assume I've got nothing setup yet.
Related devices:
Roland MPU-401 on Port 330, IRQ 2/9
Sound Blaster config
port 220
IRQ 5
DMA 1
High 5
It wants to setup it's own MIDI ports on 330...
Wavetable on port 620
I can't get the DOS setup to work, as it says I'm not using DOS, even with setver and booting from F8 : Command Prompt Only.
The Windows setup works, but then breaks my Roland MPU-401, causing anything played via port 330 to go nuts. I can't disable the AWE64 MIDI port either as it seems that the program to configure the thing is DOS is how I do so...
Help?
Reply 1 of 5, by PhilsComputerLab
First configure it in Windows. Change the MPU401 of the AWE to 300.
To configure MS-DOS mode, do NOT use the DOS 6.22 drivers, they won't work.
You need to use the 95dosapp.exe drivers as well as ctcmbbs.exe drivers.
95dosapp comes with a readme that you need to follow to install the drivers.
I've done a video tutorial on this which might help a bit: https://youtu.be/ZiSM5pUGab4
Reply 2 of 5, by alexanrs
You should be able to change the AWE's MPU address through the Device Manager
Reply 3 of 5, by Ticondrius
Thanks for the hand guys. Back in the day when I ran Win98SE on my main PC, I had a PAS16, and then later a Live!...I'm rather rusty at the old Win98/DOS cross configuration tricks now, where I used to pride myself on them. 😢
Reply 4 of 5, by dr_st
philscomputerlab wrote:
First configure it in Windows. Change the MPU401 of the AWE to 300. […]
This is awesome, but seems quite convoluted.
Is it just a matter of the DOS 6.x versions of CTCM/CTCU refusing to run if WINBOOTDIR environment variable is detected? Because they always worked fine for me once that is worked around.
It the CTCMBBS you show in your video basically contains versions that do not have this limitation? Or is it that somehow "booting into MS-DOS mode" from Windows avoids setting that variable altogether, as opposed to normal DOS boot (BootGUI=0)? Or is it another setting somewhere?
Reply 5 of 5, by PhilsComputerLab
In the video I am following the readme file and doing it the Creative way.
Creative didn't want noobs to run the DOS installer under a Windows 9x system.
