First post, by Stretch
Please share links to videos or articles comparing Voodoo2 with Voodoo3 image quality in Glide/OpenGL/D3D games.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
wrote:Please share links to videos or articles comparing Voodoo2 with Voodoo3 image quality in Glide/OpenGL/D3D games.
Well, what is your opinion?
Voodoo2's blurrier and i'm not talking about the DAC filter but the image signal. There's also diagonal interference which is far more noticable on TFTs
wrote:wrote:Please share links to videos or articles comparing Voodoo2 with Voodoo3 image quality in Glide/OpenGL/D3D games.
If you run out of ideas for your Youtube channel, maybe you can create a video comparing a Voodoo 2 and Voodoo 3 at 640x480 or 800x600.
About 15 years ago I sold my V2 and V3, but I recently purchased a V2 on ebay for my retro PC.
My motherboard doesn't support the AGP V3 and I can't find reasonably priced V3 PCI.
I'm not quite sure what you are after.
It is common-knowledge for the past 15+ years that the V3 (AGP or PCI) IQ is superior to V2 single or SLI. Any pass-thru system will be inferior to a single-card solution. GLIDE-Wrappers or DOSBox are probably better than the real thing at this time: V1 or V2.
If you have only one choice to make for your legacy system, you choose V3.
I think the V3 solved any excessive smoothness and interference caused by V2 rendering + passthrough cable even if it probably was much better that the V1.
Thanks for the feedback, I'll stick with my V2 single.
I don't use pass-thru though, since my Dell U2412M has DVI, DisplayPort, and VGA input.
