First post, by King_Corduroy
Ok guys I really need your help with this, I just picked up a custom build generic Omnitech Pentium III system and in order to get it working properly I of course need to figure out what all the drivers were because the HDD was removed.
Any help would be amazing, I think I've googled everything on here but I couldn't find anything. 🙁
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 1 of 14, by pewpewpew
It's not an M64?
Reply 3 of 14, by Sutekh94
"VDC-M64AGP16" seems to indicate a TNT2 M64 with 16MB VRAM.
My YouTube | My DeviantArt
Reply 4 of 14, by King_Corduroy
pewpewpew wrote:
It's not an M64?
Is it? I cant find any that match visually.
Reply 5 of 14, by pewpewpew
Welcome to M64! Possibly this was the most varied card produced -- someone else here likely knows better, but safe to say there are /lots/ of M64.
Reply 6 of 14, by King_Corduroy
So will any M64 drivers work or am I just pretty much fucked and I should get a better card. 🤣 If the latter what card would you suggest for a Windows 98SE machine running Pentium III 1ghz with 512mb RAM.
Reply 7 of 14, by alexanrs
Its an nVidia card. Just get whatever Detonator works best with old TNT2 cards and have fun.
Reply 9 of 14, by brostenen
Look's like eighter an M64 or Vanta. "NV-777.0" and "M64AGP16" seems to point to it.
It is most likely an TNT2-M64 with 16mb of ram. The misplaced ram chips are to be found on other M64's.
Especially Leadtek Winfast cards... Like this one here.
Reply 10 of 14, by alexanrs
Honestly, with PCI and AGP cards I just plug them in (observing voltage issues, of course) and get the Vendor ID and Hardware ID.
Reply 11 of 14, by QBiN
You could also try Linux for this. Just a quick "lspci" and you'll get a description of all the discovered hardware by ID.
Reply 12 of 14, by idspispopd
There are also Windows tools do get PCI vendor and device IDs:
PCITree http://www.pcitree.de/
( PCI-Z http://www.pci-z.com/ - no support for Win9x is mentioned)
Some more tools for DOS are linked here: http://www-pc.uni-regensburg.de/hardware/TECHTOOL/ (German, but easy enough to understand, or you can use Google Translate)
That said, TNT2 M64 was my first thought. A bit underpowered for a P3 1GHz, it will probably be the bottleneck for most games. You may have to use lower resolutions. Still, depending on the games you want to play it may be totally adequate. A GF2MX would be a better match, maybe even something faster.
Reply 13 of 14, by HighTreason
Also you can, at least on some motherboards, hit the Pause key just after the POST screen to make the system wait on the Configuration Table. A list of PCI Devices should be present at the bottom, just above where the "Starting MS-DOS..." text would appear. I use this one a lot when boards has onboard devices I can't identify, for example, Ethernet built into the chipset. All you then have to do is check the IDs on the net, such as here.
Reply 14 of 14, by brostenen
Or looking it up at this place too:
http://pcidatabase.com/
http://pcidatabase.com/search.php?device_search_str=agp
EDIT:
Look's like HighTreason came before me, as I did not look at the link he posted.
