First post, by Blutwurst
hello there,
i have a little problem with ultima IV with the 256 colors and music patch. it seems to work well, with nice music and all in dosbox as well as in windows (using XP with sp1). problem is, i dont get any further than the start menu, since i cannot use the keyboard. it recognizes the first keystroke so i get to the menu, but then every key i hit does not change anything (should't it be up- and down- keys?) i hope someone can help me and i hope i m not just so dumb not to find the right key 😀
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
ultima 4 vga upgrade is kinda bad. if you press a wrong key during the intro the system halts.
use only the keys specified (e.g the capital in the commands)
Water flows down the stream
Reply 2 of 3, by Blutwurst
thanks for the fast answer, but i still dont get it, what do you mean by capital? what key do i have to press exactly??
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
in the menu there you have something like
Continue journey .....
New adventure
There is (if I remember correctly) on one the letter in a different color .
That's one you should press.
