First post, by kixs
Went through my HDD "collection" and there seems to be around 10 drives bad - not even recognized in BIOS (tried all the jumpers settings). Sizes from few 100MB to 80GB.
What do you recommend to do with them? 😉
Reply 1 of 17, by 133MHz
Take the magnets out and re-purpose them. I keep some screwed to a wall to hold screwdrivers and other ferromagnetic tools for quick access. With enough of them you could probably build a generator.
The platters make for nice wind chimes when hung on strings.
Very old drives might have memory, logic or D/A chips worth salvaging on their circuit boards.
http://133FSB.wordpress.com
Reply 2 of 17, by JayCeeBee64
Rank Retired
Retired
^ What 133MHz said.
(Plays around with the nifty magnets from a recently dead 40gb WD HDD 😁 ).
Ooohh, the pain......
Reply 6 of 17, by Sutekh94
saturn wrote:
Make a clock out of one. Take them apart and turn in the platinum and aluminum. Have fun with the magnets.
On that note, there's also making a speaker out of one.
My YouTube | My DeviantArt
Reply 7 of 17, by Oldbitcollector
Recycle them!
Our company collects the drives which cannot be used in a large bin, then they are sent to a facility which pulls out the platters, the metals, and the circuit boards for recycling. Naturally, we have a lot of hard drive magnets too. 😀
Reply 8 of 17, by brostenen
Remove the magnet's and mount them in the back of a long piece of wood.
Mount that on the wall in the kitchen and hang you'r kitchen knifes on it.
Reply 12 of 17, by meljor
Get creative...
    47.02 KiB
Reply 13 of 17, by Logistics
Remove the magnets and put one on the end of your automobiles' oil-pan drain-plug. Next time you drop your transmission pan to change the filter, pop one in there near the original magnet. Or you can make a ring with a hose-clamp and glue a bunch of HD magnets to it and wrap it around your oil-filter.
Reply 16 of 17, by saturn
Those metal shaving scare the crap out of me. Were do they come from I think... what is wearing out I think.... but its beater if they collect on the magnets and not in the tans/engine. What scares me even more is that my car's tans never have a filter and it completely sealed.... 😵
Anyway good idea. 😎
Reply 17 of 17, by Logistics
What is it? A BMW? My Paps and I have ressurected many a BMW , with those lifetime fluid transmissions, which were sold because they "need a new transmission", and all they really needed was nice, new fluid. It's not as easy as normal to do because there is no dip-stick/fill-tube. You gotta get under the car or put it on a lift and pump new fluid in through a fill-point. But that's for another thread, and another forum.
But I would still use hard-drive magnets for this very purpose because they are just so strong!
