Blitz-92 wrote:http://i64.tinypic.com/vos6xd.jpg
How can I fix it? Thanks! […]
Where did you plac "dosbox.conf" ?
The file should be the same place as dosbox.exe and other dll exist.
And that the contents of dosbox.conf shall be;
[sdl]
fullscreen=false
fulldouble=false
fullfixed=false
fullresolution=desktop
output=ddraw
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
[dosbox]
language=
machine=vga
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=hq3x
[cpu]
core=dynamic
cycles=auto limit 60000
cycleup=0
cycledown=0
[mixer]
nosound=false
rate=44100
blocksize=2048
prebuffer=10
[midi]
mpu401=true
intelligent=true
device=default
config=
[sblaster]
type=sb16
base=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=44100
[gus]
gus=true
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=44100
tandyrate=22050
disney=true
[bios]
[dos]
xms=true
ems=true
keyboardlayout=uk
[modem]
modem=false
comport=2
listenport=23
[directserial]
directserial=false
comport=1
realport=COM1
defaultbps=1200
parity=N
bytesize=8
stopbit=1
[ipx]
ipx=false
[autoexec]
cls
mount c "C:\"
C:
Then running Dosbox.exe , you'll get a prompt in dosbox window.
