486 doesn't post
First post, by psychz
Been trying to set up an ECS UM8810 board with a 486DX/33, but it doesn't seem to pass its self-checks. PhoenixBIOS code seems to be 1-3-4-1, "Test 512 base address lines". Any insight on what this actually means? The CPU is tested working on another Biostar mobo. (Actually I think this error code has to do with memory?) Is the board dead/fixable?
Stojke wrote:
Reply 1 of 9, by feipoa
Jumpers all set correctly? What about CMOS? Try different RAM and cache?
Reply 2 of 9, by psychz
The CPU jumpers were all set according to TH99 docs and the board's own tables, can't think of anything else having to do with them 😒 Tried various pairs of RAM to no avail, however no CMOS clear done yet. Also I don't know the status of the cache chips, will test them elsewhere tomorrow and report back. Thanks!
Stojke wrote:
Reply 3 of 9, by brostenen
Is this the manual? You could cross-check settings.
I know it is of bad quality, though it's the only one I can find.
http://www.elhvb.com/mobokive/Archive/Ecs%20- … ual/um8810p.zip
Reply 4 of 9, by feipoa
Another forum member has this board and got it stable. =My Cyrix 5x86 systems : 120MHz vs 133MHz=
Reply 5 of 9, by PCBONEZ
Yes, you are right, it means bad RAM.
It is telling you to test the first 512k but that's a logical address (so the wording "base address lines") not the physical address.
I myself am clueless as to how to get from a logical address to a physical address....
If RAM has been been in a socket for ages sometimes an oxide layer builds up in the connections. (Yes, even gold oxidizes a little over time.)
If that's the problem removing and reinstalling the RAM a few times will rub the oxidation off where it matters and it will work again.
If that doesn't do it then try a different RAM module.
Reply 6 of 9, by PCBONEZ
Related "Fun Fact".
The US Navy, because their equipment has to deal with salt-air, usually chooses silver over gold for electrical contacts.
Why .... Silver oxide is almost as conductive as silver.
Reply 7 of 9, by Tetrium
PCBONEZ wrote:
Related "Fun Fact". The US Navy, because their equipment has to deal with salt-air, usually chooses silver over gold for electri […]
Related "Fun Fact".
That's actually quite smart 😀
My retro rigs (old topic)
Report spammers here!
Reply 8 of 9, by bbhaag
Did you find a solution yet? I'm also having trouble getting a 486-100 with a Phoenix BIOS to post on my DEC 466. I've tried two so far but no luck even after trying the suggestions in this thread.
If you find a solution post it up. I realize it's two different MB's/CPU's and BIOS's but who knows it might help.
Thanks
Reply 9 of 9, by psychz
No, sorry, didn't have the time to test it, will do tomorrow. I seem to recall having tried other RAM configurations as well, though.
Stojke wrote:
