First post, by brotalnia
I currently have a Windows 98 SE computer with a Voodoo Banshee on board. How do i go about upgrading to a Voodoo 3 without reinstalling Windows in the process?
Should i just swap the video cards and then install the Voodoo 3 drivers? Do i need to remove the Banshee drivers? Is it better to remove the Banshee driver first, and then swap the cards, or can i do it after?
Finally, what is the proper way to uninstall the Banshee driver? Is it done through the Device Manager? I would appreciate it if someone could clear up the process for me.
Reply 1 of 4, by alexanrs
It is usually better to remove the drivers (it they provide an uninstaller in the "add/remove programs"), but it should be fine to just swap the cards.
Reply 2 of 4, by Arctic
If you want to be sure to have no driver leftovers then uninstall the drivers in the control panel
and run driver cleaner before you swap the cards.
Reply 3 of 4, by leileilol
Device manager is enough. It's not a mdoern nvidia card; you can do it
Voodoo drivers often share filenames and will overwrite each other in driver installations, and a Banshee is more or less a V3 proto-relative, so the upgrade should be painless. 😀
Reply 4 of 4, by boxpressed
Before swapping out a video card, I make sure to change the adapter to "Standard VGA (PCI)"--or something like that--and then reboot.
At that point, you can uninstall the Banshee drivers if you like. Then swap in the V3 and load the V3 drivers.
