Commodore 64 + 1541
First post, by krivulak
Guys, I don't know, how much can you all help me, but I have an unsolvable problem for me right now. I got Commodore C64 with 1541 Disk Drive for free. That sounds nice, BUT i can't load anything. I got some floppy disks from previous owner, but it could be easily bad. It does very much something like this: https://www.youtube.com/watch?v=ebtYDP8hfC0
I spend whole day fiddling with this, I cleaned heads, but no such luck. I thing alignment could be wrong, but I don't really know how to fix that without callibration software. I don't either have Datasette, so I can't play with tapes. So now I am stuck and can do nothing about that.
Reply 1 of 5, by vladstamate
First thing you could do, is chose a disk you don't mind losing the contents from and try to format it. Then read it back. If the disk does not format it is possible there is an issue with the drive. If the disk formats but not read it is even more likely this is an issue with the drive. If both format and read are ok, then very likely the old data on the disk is gone but your HW is at least good.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 2 of 5, by krivulak
I tried formatting already, didn't work. Also, I visually checked electronics in 1541, nothing seems wrong.
Reply 3 of 5, by matze79
What Error did you get ? (got one ?)
First check all Cables, Powersupply Voltages, clean drive head, (may need head realigment)
As far as i know realigment requires a Osciloscope and the right knowledge.
Does another Drive work ? if not swap the CIA's and test again.
Maybe you want to get a SD2IEC Device ? and use a SDCard with your C64.
Reply 4 of 5, by krivulak
I don't remember exactly, it was few days ago and I can't check it right now, because my old trustworthy TV blew up, so I have to find another one.
I bought new cables, cleaned heads with that "special" floppy disk cleaner, then with q-tip and rubbing alcohol (it was really, really dirty), but it didn't do anything with reading data.
Also, I don't know anybody, who has working drive, and it is really expensive for buying in place where I am living.
Reply 5 of 5, by seob
You could try this command OPEN 15,8,15,"I":CLOSE 15 to reset the heads. Do this WITHOUT a disk in the drive.
