the board doesn't have on board anything, witch means it has no settings for COM ports or anything remotely related to mouse operation.
The isa multi I/O controller I'm using is working fine - fdd and HDD work perfecty, and I was able to use my mouse with said controller on another motherboard, so that's not to blame.
I'm thinking the problem might be related to the keyboard controller. When I got the board it was really damaged and dirty - broken traces, a missing capacitor, the works. I repaired the broken traces and added another capacitor in place of the missing one, but the KB controller was missing as well. I have no ideea what originally came with this board - probably an AMYKEY controller, but I don't have one of those on hand so I'm using an Opti controller I got off a dead 486 board. I also have a nec and an intel kb controller on hand, it seems to like the opti best.
Problem is, it doesn't work perfectly. If I press num lock, the light will not go on and the keypad will not work. Sometimes it makes the keyboard not work at all requiring me to reset the machine.
So - could it be related to the keyboard controller somehow?
P.S. Merry Christmas!
