First post, by brotalnia
- Newbie
I want to mount a fan on my video card's heat sink, but i don't know which type of fan is designed for that. Help me choose which one is most appropriate.
Here are my choices:
EverCool EC4010M12EA, EL Bearing 5000rpm http://i.imgur.com/9WYKDul.jpg […]
Dimensions: 40 x 40 x 10mm
Rated Fan Speed: 5000 RPM
Air Flow: 5.75 CFM
Noise Level: 21 dBA
Power Consumption: 12 V, 0.07 Amp.
Watt: 0.84
Bearing: EL Bearing
Connector 3 Pin Molex
Life /Hours/: 40000
EverCool EC4020M12EA, EL Bearing (5000 RPM) http://i.imgur.com/YCzNmaG.jpg […]
Dimensions: 40 x 40 x 20mm
Air Flow: 4.17 CFM
Noise Level: 21 dBA
Power Consumption: 12 V, 0.08 Amp.
Watt: 0.96
Bearing: EL Bearing
Life /Hours/: 40000
Fan 40mm, Spire SP04010S1M3 http://i.imgur.com/NSTvHI0.jpg […]
Model Number: #SP04010B1M3
Dimensions: 40x40x10mm
Power: 12V
Speed: 3500 RPM
Air Flow: 5.4 CFM
Current: 0.07 A
Noise Level: 23 dBA
Bearing: Sleeve
Life Hours: 50,000
Connector: 3 Pin 3 wire with 14"" tail
EverCool EC4010M12BA, 2Ball 5000rpm http://i.imgur.com/9ubNPPI.jpg […]
Air Flow: 5.75 CFM
Noise Level: 21 dBA
Watt: 0.84
Bearing: 2 Ball Bearing
Life /Hours/: 50000
Does the "bearing" matter? I don't really know what the differences are. I plan to mount it to the heat sink using bolts and it will be positioned horizontally (facing the ground). The video card is a voodoo 3 2000 if that matters.
