First post, by clueless1
So I'm newly reacquainted with DOS retro gaming 😀 A lot of DOS commands are coming back to me after 20 years away from the OS, but a couple questions have come up for me:
1) is there a way to alphabetically sort the file/folder structure automatically with a "dir" command? I figured out "dir/og" to sort nicely but the extra few characters are getting annoying. I seem to remember back in the day that some 3rd party defrag program did this as party of its process? Norton maybe?
2) is there a way to force the optical drive to D: when you have multiple hard drive letters? For now, I blew away my extended partition and logical drives since I am not close to filling up C:. This made assigning D: to the optical drive easy. But at some point I will need to add an additional 2GB partition or two (using an 8.4GB Samsung).
Thanks!
Reply 1 of 9, by Gamecollector
1) DIRCMD environment variable.
The command is "set DIRCMD=/og" for your example.
2) /L:<letter> command switch for MSCDEX. Others DOS cd drivers use the similar method but the switch may be different.
Unfortunately there is no way to move cd-drive before FDD or HDD in DOS.
And some game want cd-drive as D and not work with others letters.
Reply 2 of 9, by konc
And since Gamecollector excellently addressed your questions, let me cover the final bit about defrag: Both MS defrag and Norton's Speed Disk allow you to sort the files/directories. Norton's option explicitly says "sort files blah blah" AND "move directories to the beginning", while MS's version (DOS 6.22) has the options simplified: If you choose to sort, it will also move the directories to the beginning.
btw for those working on FAT32 with the "DOS" from Windows 98, FreeDos defrag also allows sorting
Reply 3 of 9, by clueless1
Gamecollector wrote:
1) DIRCMD environment variable. The command is "set DIRCMD=/og" for your example. 2) /L:<letter> command switch for MSCDEX. Othe […]
Thanks, Gamecollector and konc, especially for the DIRCMD variable and background on Defrag/Speed Disk.
I was aware of the /L switch and was using it. However, here was the situation I faced: When installing DOS, I partitioned my hard drive into four drive letters. So my optical drive took drive G: and I could not force it to D: because the 2nd hard drive partition already had a lock on that drive letter. I did not know how to shift all the hard drive letters over by one to reserve D: for the optical.
Is Norton Speed Disk freely available from any reputable sources?
Reply 4 of 9, by JayCeeBee64
Rank Retired
Retired
It isn't as far as I know. Symantec (like Microsoft, Adobe and others) keeps a tight grip on their IP.
You could go for "disreputable" sources, but then you're on your own.
Ooohh, the pain......
Reply 5 of 9, by clueless1
I'd forgotten that MS Defrag was licensed from Symantec. It does everything I was wanting, so no need for Norton Utils. 😀
Still not sure if it is possible to retain the optical drive as letter D: if I add a 2nd HDD partition. Anyone?
Reply 6 of 9, by Gamecollector
No.
Because DOS assigns HDD letters before config.sys processing.
There is the ASSIGN command but it only creates drive letters, not makes the original letter free.
Reply 7 of 9, by clueless1
No. Because DOS assigns HDD letters before config.sys processing. There is the ASSIGN command but it only creates drive letters, […]
No.
Thank you Gamecollector.
Reply 8 of 9, by gerwin
You can use a batch file (located in a folder that is in your PATH variable) to always call dir with the sorting options you like.
In addition one can use a dir replacement:
1) D by Feedingdragon
2) 🤣
3) NDIR
4) Access-D ... Nowhere to be found so I attached it here.
    access.zip
    23.55 KiB
    57 downloads
Reply 9 of 9, by clueless1
For me the solution was to run defrag with the file sort option. Then you don't have to mess with dir.
