First post, by RokkDog
Hello to all.
I have read tons of posts about dos and dosbox but can't find the answer to my problem.
The scenario is that I have a dos based WarCraft 2 game that i want to make portable. I have other games that i have been able to make to start from anywhere from just double click the bat file i have made to execute game in dosbox. However WarCraft 2 performs a cd check so i have to have iso file of the game mounted. That's not a problem, i just changed the game file to image file in my bat and it loads the cd to dosbox. HOWEVER, after this i have to always type WAR2 to be able to play the game. My problem is that i want dosbox to automaticly start the game exe after it has mounted the c and d drive. Is this possible in any way? Can you tell dosbox to start exe automatically when it is started. Autoexecute is not an option, the bat file runs after it and the same variables can not be used in dosbox itself.
So once more to make it a bit clearer.
I have a bat file that opens iso file in dosbox (all files are in the same folder)>
Dosbox automatically mounts current folder as c: and the iso file to d: (no matter where my folder is and i like that a lot)
NOW THE PROBLEM
How to make the Dosbox automatically start the game after above?
Dosbox
