First post, by kanecvr
- Oldbie
Hi guys. I've been trying to get my only 386 board that has L2 cache working for the last couple of months. There are two related threads on Marvin, but they tackle separate issues, but they have been resolved so I'm opening up a new thread regarding the latest issue I'm having with the board.
I figured out the board originally uses a NEC keyboard controller and I sourced one from a dead motherborard, BUT keyboard still doesn't work correctly. Here are the issues I'm having:
- AT keyboard will usually refuse to work at all - after posting, the machine displays a "Keyboard Error, press F1 to continue". Pressing any key on the keyboard will make the machine beep, but it will not register any actual characters / commands.
- I can use a PS/2 keyboard /w a din to mini-din adapter, and everything seems to work sans the num lock. When pressing "Num Lock" the machine stops accepting input from the KB until I turn it off and on again. Num keys will not work even if I set "Num Lock on at post" from bios. With said setting on, pressing any numpad key will make the machine beep like it won't register a valid keypress. Setting it off will register 8, 2 4 and 6 as arrow keys and the rest as insert, end and such.
I checked the back side of the board and someone seems to have previously replace one of the ICs under the KB controller (S 74F00N I think). Could this have been replaced with the wrong IC? could this be causing the issues?
Said IC is a 2-INPUT POSITIVE-NAND GATE - not electronic-savvy enough to know what it does.
