Game Port not Working
First post, by rick12373
I followed Phil's excellent guide here https://www.youtube.com/watch?v=Y6HzttM6wS0 for setting up the Windows 98 exit to DOS config. Everything works well apart from when I exit to DOS my game port and joysticks do not work. They are detected and work in Windows though. I currently have an ISA Awe 64 for a sound card.
Anybody have any ideas why this might be?
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 10, by alexanrs
Have you tried running DIAGNOSE /S after exiting Windows?
Reply 2 of 10, by rick12373
I have DIAGNOSE in \CTCM & \SB16. Which one should be used?
SB 16 Value CT2770
Reply 3 of 10, by gdjacobs
SB16 is your Awe64 drivers for DOS?
Reply 4 of 10, by PhilsComputerLab
Try the one in the SB16 folder!
Reply 5 of 10, by rick12373
I tried it and it didn't work. Weird...
SB 16 Value CT2770
Reply 6 of 10, by PhilsComputerLab
What happens when you run it?
Try running CTCM from the CTCM folder, see if you get any messages.
Reply 7 of 10, by rick12373
If I run DIAGNOSE /S I get the card settings listed. If I run DIAGNOSE on it's own it detects all of the hardware and tests successfully.
The same happens with DIAGNOSE in the CTCM folder.
SB 16 Value CT2770
Reply 8 of 10, by PhilsComputerLab
Well that's what you want 😀
But not sure why the gameport wouldn't work.
Reply 9 of 10, by rick12373
Yeah it works in Windows and everything else works perfectly. I wish my old AWE32 still worked but the music playback on that became garbled for some reason. This was the only other card I had available.
SB 16 Value CT2770
Reply 10 of 10, by rick12373
Well this is frustrating...
SB 16 Value CT2770
