Help loading fakeshar.com
First post, by NapoleonDynamite
Okay so I have windows 3.1 installed in dosbox and I want to try installing a game but it requires a share file to be installed which I don't have. So is there a way I could get one or do I have to install fakeshar? If so then how do I install it? Thanks.
Reply 1 of 20, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Which game needs share.exe (or share)?
You can try fakeshare but it is .... fake... If the game needs share functions it might crash and cause data corruption when run with fakeshare.
You just run fakeshare before doing anything else...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 20, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 4 of 20, by NapoleonDynamite
The game I am trying to install is ultimate yahtzee it just says needs share file installed.
Reply 6 of 20, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I think vDos omits graphics capability, so not that useful for running Win3. There is a link to the fakeshare TSR program in the Win3 guide in the guides section of the forum, but if the game still complains with it resident then the faking isn't sufficient. Note that Windows For Workgroups 3.11 includes a file sharing VxD (VSHARE.386) as part of its networking support that might be effective in appeasing the game and/or its installer, but of course if you actually try to use some kind of LAN multiplayer option in the game then don't expect that to work correctly.
Reply 7 of 20, by Dominus
DOSBox Moderator
Loading vshare.386 doesn't work as it can't function (same as share.exe). But AFAIR, loading fakeshare before starting Windows 3.x makes most programs be fine (MS Office for example). I don't know if I needed vshare.386 though in addition...
Reply 8 of 20, by ripsaw8080
Rank DOSBox Author
DOSBox Author
VSHARE.386 is a VxD version of SHARE.EXE, and you don't need both. However, the point here is not about what functions correctly -- I think the point has been fairly driven home by now that file sharing can't function correctly -- the point is getting the game in question to at least shut up about file sharing, and VSHARE.386 can do that much; or at least I've seen it do so for a different game, but it may be academic because the OP doesn't seem to be using WfW. 😉
Reply 9 of 20, by Dominus
DOSBox Moderator
What I meant with functioning is that MS Office wouldn't run with vshare.386 loaded, only with fakeshare. I guess programs like MS Office stuff do more testing than just look whether vshare.386 is loaded...
Reply 10 of 20, by NapoleonDynamite
So I now have vdos installed how do I install the game?
Reply 12 of 20, by NapoleonDynamite
So I can actually now install windows 16bit/32bit games? Cause I also have star trek pinball I would like to run since it wont work using wine on my mac or in 3.1 windows.
Reply 14 of 20, by NapoleonDynamite
Okay thats good. For some reason star trek pinball did not let me install it I think I may have to burn it to a cd to run it since some games do that.
Reply 15 of 20, by Bluescreen
Can anybody tell me, where I can download the file "fakeshar.exe"?
All links I found in this board (e.g. Windows 3.1x DOSBox Guide) or via google seem to be dead.
Thanks 😀
Reply 17 of 20, by collector
Dominus wrote:
I need to fix all these links. Dropbox dropped its public folder and every link is now broken ;(
Which is why I wish people would just attach files like that here instead of using a download service.
Reply 18 of 20, by Bluescreen
Ok. When you have the time to do so - please start with the link for fakeshar 😉
Thanks
Reply 19 of 20, by Errius
Hello, where can i obtain fakeshar.zip?
edit: I have found a similar program, NOSHARE.COM, which serves the same purpose. I will attach it here.
Is this too much voodoo?
