HP xw8600 dual xeon help needed!
First post, by varanoidas
OK, so I decided to buy an hp xw8600 workstation motherboard because I already had a pair of lga771 quad core xeons and the board looked nice with 8 slots of ram, dual pci-e 16x, pci, pci-x... I paid 40 euro for the board, 60 for shipping and 40 for taxes and 30 for 2gb ecc ddr2! 170 euro total! 😢 And when i got it home and hooked it up it didn`t work with my atx psu because the pinouts of 6 and 8 pin connectors are not standart, but when i rewired the 8 and 6 pin plugs it still didnt work. 😢 I think that the pinout of the main connector might be different although when i tested it with my meter at least all ground pins appear where they should be. So if anyone has any ideas plase help me out.
I know this isn`t exactly a vintage system but... I don`t know where else to ask. But then again, I think I saw a "retro" Windows XP build with an i5 or something like that around here 🤣
Reply 1 of 51, by Snayperskaya
Did you check beforehand if that motherboard is compatible with standard ATX pinouts? You might've fried the motherboard if it isn't. Proprietary (mostly from OEMs like HP, Dell, IBM, etc) server parts tend to have this problem.
Safest buy would be a Intel, SuperMicro or Tyan motherboard since those are designed to work with off-the-shelf parts mostly.
Reply 2 of 51, by varanoidas
I did check it before, but i didn't find any info on it so I assumed that it is standard connectors. If i knew it, i wouldn't have bought it 😁 I knew that Dell uses proprietary connectors, but i thought that HP uses standard atx. The light on motherboard does light up though! When i hook it up the fan spins up for a second but thats it.
Reply 3 of 51, by Snayperskaya
Maybe the CPU model require a BIOS update? I have a pair of dual 1366 SuperMicros that only boot up with E55xx Xeons (there's also the fact that one of them "died" after a BIOS update that went without warnings or errors, so, no dual X5690s for me until I replace that chip 🙁 )
Reply 4 of 51, by PCBONEZ
The connectors are standard, they are not PCIe however.
They are like the 4-pin "P4 connector" only with more pins to handle multiple CPUs.
Sometimes there is an additional 4,6 or 8 PIN specifically for RAM. (Which has it's own VRM.)
PCIe is the proprietary one. - The others came first.
PCIe connectors have the polarity reversed from standard. (They are wired backwards.)
These systems don't use standard ATX PSUs. They use EPS12V PSUs. (The SSI standard.)
There is little difference except for the connectors available.
There are many combined standard ATX/EPS12V PSUs around if you look close enough.
(Because some are but don't say so.)
If in your tinkering you connected something with reversed polarity you may have fried the PSU, the motherboard or both.
Reply 5 of 51, by PCBONEZ
The xw8600 only officially supports E54xx, X54xx, E52xx, X52xx CPUs.
While technically the chipset should support other chips HP may not have provided BIOS support for them.
The HP xw____ systems are known caps blowers. Heat issues.
I know most of the caps on that model are solid polymer but you should closely inspect those few that aren't.
Reply 6 of 51, by varanoidas
Sorry for your loss.
I did find that the connections different so i rewired my connector by finding which pins on board are ground with meter and double checked by tracing the other pins to nearby 16v caps for +12v. Could the main connector be different? Maybe by just one pin? My xeons are 3ghz (or maybe 2.66,but most likely not) quad cores from 2008 mac pro so I think they should be supported (cant see their model because their fronts are ruined by apples thermal glue or whatever that crap is) and I don't have any other lga771 chips. Could it be the ram? The xeons in mac pro 2008 are 5400 series as far as i can find
Reply 7 of 51, by varanoidas
Caps appear to be fine
Reply 8 of 51, by PCBONEZ
What loss?
Yes. What are you using?
Reply 9 of 51, by varanoidas
Snayperskaya said that he killed a xeon after bios update. That loss
Reply 10 of 51, by PCBONEZ
Gotcha.
These systems require FB-DIMM. - Fully Buffered DIMM.
Reply 12 of 51, by PCBONEZ
varanoidas wrote:
Two sticks of ram same as this http://www.ebay.co.uk/itm/1GB-PC2-4200F-44-11 … A-/111233330934
It is fully buffered. Other sticks dont even fit.
That is FB-DIMM but it's only PC2-4200F.
The system calls for PC2-5300F. (DDR2-667 Fully Buffered)
And socket 771 boards are very picky about RAM type/speed.
Fortunately 1Gb and 2Gb sticks are quite cheap these days.
You can ignore the ECC part of the description. All FB-DIMM is ECC.
Reply 13 of 51, by PCBONEZ
Not supposed to. I've seen people manage it.
I think some people install RAM with hammers.
Reply 14 of 51, by varanoidas
Could it really be that ram is too slow? In that case shouldn't it display an error code with its led or something? Now it just spins up the fan for a second and powers off.
Reply 15 of 51, by varanoidas
Guess I am going to have to return the ram back to the shop and ask if they have PC2-5300F. Thank you your your help. Btw, do you know if it can take a single dimm or do they have to be in pairs?
Reply 16 of 51, by Snayperskaya
On 10+ years tinkering with hardware that was the first time I've ever seen a BIOS dying after a successful update. IT never ceases to amuse me 😵
You will need at least one DIMM for each CPU installed.
Oh, try to edit your posts to avoid double (triple, etc) posting.
Reply 17 of 51, by PCBONEZ
Yes I believe the wrong RAM in a socket 771 board could result in the old "fan kick" scenario.
I'm on a dual skt 771 system right now. (Kind of my thing.)
I could tell you for sure if I had any PC2-4200F around but I don't think I do.
From the discussion so far the possible problems are bad or incompatible PSU, bad motherboard or wrong RAM.
The RAM is probably the cheapest to explore unless you have a better (for this) PSU on hand.
Reply 18 of 51, by PCBONEZ
You can test the board in single CPU mode.
That's probably a good idea because it's less load on the PSU.
Reply 19 of 51, by PCBONEZ
Not all socket 771 boards are like that but given this one is an HP this one probably is.
The next problem is figuring out which RAM slots go to which CPU.
Testing in single CPU mode is just easier.
