First post, by pjburnhill
Hi,
Just wondering if it's possible at all to use the command prompt to change .conf parameter during launch?
For instance
dosbox.com -conf url\to\dosbox.conf %1 %2 %3
etc. and in dosbox.conf you could have
mapper=%1
for instance.
This would mean you could have game-specific .map files without having to change the .conf or create game-specific .conf for each game to point to the correct .map.
Is this sort of thing supported by dosbox launch parameters?
Cheers,
PJ
Reply 1 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yes, -conf and -userconf, you need to read up what does what (I'm always confusing them) but the last one overrides the first one (except maybe mapper needs to be defined in only one conf - idk) and whatever is written in the autoexec section stacks up.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 4, by pjburnhill
I'm aware of -userconf but unfortunately that's not quite what I'm after.. I'd like to change the .conf settings from command prompt, without creating a secondary .conf to override it.. I assume this is not possible?
Reply 4 of 4, by pjburnhill
Command prompt..
