First post, by superfury
Does the current Windows 10 build still use the current Onedrive account to store it's information set in the sync settings in the control panel (The synchronization of the microsoft account you're logged in on Windows 10)? If I log in on a different Microsoft account with Onedrive, will it sync the account settings in the control panel etc. with the then set Onedrive account? Or will it always use the account you've logged in using Windows login (when you start your computer)?
So if I log in to abc@def.nl with Onedrive, while being logged in on Windows using ghi@jkl.nl, will the Windows settings be synchronized with abc@def.nl or ghi@jkl.nl? Or will it always use ghi@jkl.nl?
I'm currently on Windows 10 build 10586.36.
I want to synchronize the Onedrive of one PC with an PC using a different account, but keep all Windows settings seperate on their respective accounts I use to log in on Windows.
UniPCemu Git repository
