First post, by Duffman
when I run mixer /listmidi on my lubuntu installation of dosbox - it shows no devices
So if I run MEGAMID or MIDPLAY MIDI players and try to play MIDI files I get no sound.
I thought it would default to emulated soundblaster FM synth in this case.
Is there a way to get dosbox to use internal emulation if nothing else is available?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 1 of 6, by Zup
apt-get install timidity
Maybe not that command, but timidity and fluidsynth are two packages that provide software synth capability. Also, you will need some patches and / or soundfont (available in repositories).
I'm selling some stuff!
Reply 2 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
listmidi doesn't work on linux.
midi itself does, if you configure the port correctly
Water flows down the stream
Reply 3 of 6, by Duffman
I haven't changed anything from the default settings
mpu401=intelligent
mididevice=default
midiconfig=
I tried installing timidity, dont have a soundfont though
aren't midi players like MEGAMID supposed to be able to use the FM synth in the soundblaster?
CPU: Ryzen 9 5950X
Reply 4 of 6, by Duffman
can MIDI players like MEGAMID use FM Synth?
CPU: Ryzen 9 5950X
Reply 5 of 6, by lightmaster
No infolink on this? i find it very interesting!!
Reply 6 of 6, by Duffman
is there a way to tell dosbox to fallback to using the internal soundblaster emulation if no external MIDI device is present?
CPU: Ryzen 9 5950X
