First post, by Jr_
I was able to get one of these motherboards but now I'm struggling with the large hard disk support.
As I only have a WD800BB drive available atm, I had to limit drive capacity via jumper but the BIOS only detects a 2GB drive. If I don't put the jumper in place, the machine locks up during POST.
Does anyone know if there is any updated BIOS that can support bigger hard drives?
my build
Reply 1 of 16, by emosun
Well I say google like crazy for a bios , but good luck.
I think your best bet would be a small drive/compact flash card for the os , then when the os is loaded have a drive connected to a newer controller or usb perhaps.
Reply 2 of 16, by alexanrs
Or and ODD to bypass the limit altogether.
Reply 3 of 16, by PCBONEZ
BIOS version 1.00.07.DH0 should take up to 8.4Gb drives. IDK if there was a newer revision or not.
https://groups.google.com/forum/#!topic/intel … ium/wYKJP8zJqrk
Reply 4 of 16, by Jr_
that's the BIOS in use... guess that I'm out of luck.
Probably gonna try other hard drive brand to see if I can get at least 8.4GB
my build
Reply 5 of 16, by alexanrs
Can't you just input the highest CHS parameters your BIOS can handle manually?
Reply 6 of 16, by Jr_
hmm never thought about that, I left everything as Autodetect. will try that also
my build
Reply 7 of 16, by anachronism1887
I have the same motherboard but the only IDE drives I had were 320GB Seagates. In my case, the bios detects the drive fine and will max out at 8GB or so for FAT32 (2.1GB FAT). Seagate DiscWizard (V.10.45) will allow me to maximize the disk usage. Maybe, you'll have better luck with a Seagate drive?
I tried using an IDE to CF card and I had zero luck getting it to work. Auto setting in BIOS didn't even see the card and inputting the parameters manually also failed miserably. Certainly, I could be doing something wrong since I'd never tried using an IDE to CF adapter before.
Reply 8 of 16, by fillosaurus
Have one of those motherboards. I like the onboard sound, Yamaha 70x, no need for drivers in DOS mode. I dislike the BIOS, did not detect any HDD over 8 Gb, very fussy with 2-8 Gb ones. Will try to flash the latest BIOS.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
Reply 9 of 16, by RacoonRider
You could use Ontrack disk manager, an overlay software that works even on 386.
Reply 11 of 16, by PCBONEZ
vetz wrote:
You could get a ATA PCI card.
Gets my vote.
Reply 12 of 16, by Windows9566
PCI IDE controller will be better than that lame onboard ide controller, i used one on my packard bell pc that had that 8gb limit for using a 40gb hard drive for windows 95 osr2, i used a Promise Ultra66 PCI
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 13 of 16, by 33oldnew
MHDD ?
Reply 14 of 16, by zyga64
Sorry for necroposting, but in case anyone is interested...
I've just bought TC430HX motherboard. It has last BIOS 1.00.07.DH0.
I connected Samsung SV0602H to it (60GB jumpered to 32GB). Although BIOS (disk is set up as "Auto configured") shows 8 GB - it boots normally, and whole 32GB space is visible under DOS and Windows.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 15 of 16, by White
Sorry for necropost, but i just got the same board and my 120GB IDE HDD detects as 8 GB HDD, but works fine with whole space availability. BIOS 1.00.07.DH0. The previous one 1.00.04 handles only 8 GB and i was not able to get whole space without external controller.
Reply 16 of 16, by The Serpent Rider
So the last BIOS has 128 Gb HDD limit. Good to know.
