First post, by kanecvr
- Oldbie
Hi guys. So I recently put together a 1.4GHz tualatin system and I was trying to decide what video card to use in it. I don't like using cards that are bottlenecked by the cpu, but I also dislike using video cards too weak to play period games at full details so I started benchmarking the cards I have on said system and I'd like to share the results.
==Test system specs:==
CPU: Pentium III S (Tualatin) 1400Mhz 512Kb L2 cache
MB: ABIT ST6 Intel i815
RAM: 512MB PC-133 SDRAM
Audio: On-Board AC97 (Intel PCH)
HDD: 80GB WD IDE HDD ATA133
OS: Windows XP Profesional Service Pack 3 (+98SE dual boot - tests were preformed on windows XP)
Drivers: Intel Chipset ID utility for i815 (latest 2004 version) + Catalyst 4.3 / Forceware 66.93
UT and Q3A were ran at 1280x1024 32 bit color with maximum settings, no AA, no AF. UT2004 was tested at 1024x768, medium details, medium fog distance and phisics set to low.
Maps / demos used for benchmarks:
UT: cityintro
Q3A: q3crush
UT2004: albatross (1v1 deathmatch)
==Cards tested:==
- Reference Radeon 8500 64MB 250 / 500
- Gigabyte Maya Radeon 9000 PRO 64MB 200 / 400
- Palit Daytona Gold Geforce 3 Ti 200 64MB 175 / 400
- Leadtek Winfast A250LE Geforce 4 Ti 4200 64MB 250 / 515
Other cards I have yet to benchmark on this system:
- Soltek Geforce 4 MX 460*
- Asus V8200 Geforce 3 (non-Ti -> 200 / 460)
- Hercules 3D Prophet III Geforce 3 Ti 500 240 / 500
- Chaintech Geforce 4 Ti 4600*
- Palit FX5200 256MB 250 / 400*
- Unknown (possibly BBA) Radeon 7500 64MB 128bit
- Sapphire Radeon 9250 128bit 256MB 250 / 500*
- Sapphire Radeon 9500 275 / 540 (L-shaped vram placement)*
- Connect 3D Radeon 9550 256MB AGP 4x/8x*
- HIS Radeon 9600*
*some cards are not period correct for this build but they might work really well regardless - others were selected so I could see when the CPU becomes a bottleneck (like the Ti4600 and the 9500 PRO)
==Results so far:==
==Personal Conclusions==
Out of all the cards tested today I'd select the Radeon 8500LE for this particular system. It's faster then the Geforce 3 Ti 200 (and in fact faster then the Ti500) and it's also cool and quiet. Using Catalyst 4.3 I've had no compatibility issues, not even with the usual troublemakers i.e. Dungeon Keeper II / Blood 2 / Black and White and all tested games are smooth. Even Unreal Tournament 2004 (witch I included as an "over-spec" benchmark) is pretty smooth. The card comes really close to the Titanium 4200 witch is visibly bottlenecked by the Pentium III CPU.
As you can see the same video card scores double in 3DMark 01 on an Athlon64 3200+, so keeping it in the Pentium III would be kind of a waste. In the same manner the Radeon 8500LE scores quite a bit more on an Athlon64, but the difference is not as dramatic, the card managing a little under 11000 pts on said A64 versus the ~7500 pts is gets on this Pentium III. Frankly, we're only seing CPU bottleneck with the Radeon 8500le and the Geforce 4 Ti 4200.
The 8500 has another advantage over the other cards - it's really quiet and makes almost no noticeable heat - and - like the Ti4200, you can play at high resolutions / with anti-aliasing effortlessly.
