First post, by Gootsey
- Newbie
Hey all, thought I was gonna upgrade my PC today but got a little thrown off track.
I've got an IBM PS/1 Consultant 2155-G54. I grew up with Windows 98 and a Celeron, so anything before that is pretty unexplored by me. I bought a 486DX2-66 Overdrive before and found out that was incompatible due to the bus speeds and yadayada, so I picked up a 486DX4-75 still in the original box on eBay.
I popped it in the second I got it, it booted (Hooray! No video output with the DX2-66) annnd that's it. After boot it's stuck on the POST screen with error 129 which, as far as I can find out means "Processor Changed" but it can't configure it correctly. I also can't get into the BIOS unless I remove the OverDrive from the upgrade socket and use the 486SX-25 that's soldered on.
I found this article which is for a totally different system but I think it's the same problem,
http://ps-2.kev009.com/pcpartnerinfo/ctstips/9612.htm
the reason being "this processor has a 16K internal cache and the BIOS only supports 8K". I can boot into the BIOS with the OverDrive removed and confirm that it displays 8K of cache.
Please tell me that there's a way around this roadblock and that I'm not $50+ in the hole already and still haven't found a working upgrade!
Thanks All. 😀
IBM PS/1 2155-G54 | 48SX-25 | 8Meg | Soundblaster 16 |
