First post, by jose miguel
Hello friends, please i need your help, dosbox to emulate an application ( a clock that tells the time ) like the one located at the lower right windows , the emulated but is late and desiguala with seconds to a few minutes of open .
I've adjusted the cycles and nothing. My operating system is Windows 7, 32-bit , 4GB RAM, 1.8GHz
I'd like to help you know why this happens and how to fix it for me dosbox emulates this application without desiguale with Windows clock .
Thank you for your help
Reply 1 of 1, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Please, only make one post to ask a question. Multiple posts asking the same question will probably get deleted as spam.
Try compiling DOSBox SVN with the DOSBOX_CLOCKSYNC define set to 1 in bios.cpp to keep the emulated timer ticks in sync with the host clock.
