First post, by DoomGuy II
I've read on the Microsoft website that Windows 95 does not support hard drives above 32GB.
However, I have a Panasonic Toughbook CF-25 with an 80GB hard drive with DDO installed and have two partitions, 10GB with Windows 95B and 65GB for data, as seen here.
After at least a few months of usage, I've had no problems reading, writing, and storing data so far. So, that begs the question. Is there really a limitation to using more than 32GB in Windows 95 and if so what are the downsides of it? Because again, I've had zero issues with the configuration I currently have on my CF-25 so far.
Official Website: https://dg410.duckdns.org/
Reply 1 of 3, by Skyscraper
DoomGuy II wrote:
I've read on the Microsoft website that Windows 95 does not support hard drives above 32GB. […]
Its only FDISK that cant show the size correctly with disks above 32 GB, FDISK can still partition larger drives and Windows 9x it self should handle disks up to 128GB as long as we are not talking about Windows 95A with FAT16 (max 2GB).
Reply 2 of 3, by DoomGuy II
Makes perfect sense, since I've used the Hitachi version of Ontrack DDO to partition my hard drive. So, I guess it wouldn't hurt to use a 120GB hard drive under Windows 95B as long as I use third party partitioning software or even the updated version of FDISK under Windows 98.
Reply 3 of 3, by alexanrs
You could just use 95's FDISK but input percentages instead of absolute values. It would display incorrectly but would work just fine.
