First post, by Totempole
- Member
I picked up a couple of generic Yamaha YMF724E-V PCI Sound Cards today and want to use one of them for DOS games within Windows 98SE.
I'm not having any luck getting digital audio working, I can get FM and GM to work though. For some reason, no matter what configuration I try, the DOS program will either lock up, or the whole system will lock up and reboot.
For example, when I try to configure sound in Duke Nukem 3D, the moment I attempt to test it, the whole comuputer locks up. With Death Rally, sound works, but the game crashed after just a few seconds.
So far I've tried the Labway and Yamaha 192XG Drivers from this website, and the drivers from Yamaha's website with varying results.
I've also wired up the SB-Link headers, but have no idea what it actually does. Also not sure whether the card needs to be in a specific PCI slot for SB-Link to work or not.
Can anyone suggest a good driver, or possible solution to my problem? It seems like it could be a resource conflict rather than a driver issue.
Thanks in advance for any advice.
In case it helps, this card is very similar, if not the same as the ones I've got, but I don't recall seeing "Addonics SV550" printed anywhere on mine:
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
