can't mount floppy!
First post, by Guest
hi there!
i'm new to dosbox and experience problems mounting my floppy drive as such!
i use the mount a a: -t floppy command (i tried either boxer and dos-box prompt) to mount my drive but dos-box keeps mounting the drive as a local directory which keeps me from installing (and running) my dos games!
if you can help please do!
thx!!!!
Reply 1 of 5, by eL_PuSHeR
I always mount it with backslash included:
mount a a:\ -t floppy
Works for me.
Reply 2 of 5, by Guest
did so (only forgot the backslash in the posting 😊 )
doesn't work (see above) any other suggestions?
Reply 3 of 5, by Dark Knight ez
try to use a regular slash instead of a backslash.
something to do with keyboard layout could cause this problem.
... // bda. very bda!
... // but only if you turn godo into csah.
Reply 4 of 5, by Guest
tried that, didn't work out 😢
i use bosbox anyway, so the layout is (or should be 😁 ) no problem!
any other ideas? 😕
Reply 5 of 5, by Guest
that is so emberrasing 😊
obviously i meant boxer (i'm a bit confused)
